Transmission Fluid Type???
Old Feb 26, 2006 | 10:00 PM
F23AccordLX's Avatar
Default Transmission Fluid Type???
I have a 99' Sedan LX VTEC with the 5-speed trans. I talked to my buddy whos a mechanic and he told me to get some fully synthetic transmission fluid so it would shift a lot easier (131650 miles on the odometer, still runnin' strong, YA YA HONDA). I went to AutoZone to get some and they told me 10W30 Motor oil was what had to be used!!! So i believed the guy and bought 2 quarts of CASTROL SYNTEC. Was motor oil a good choice??? If anyone knows any good fully synthetic tranny fluid, let me know. Thanks
Old Feb 26, 2006 | 10:27 PM
marbro's Avatar
Default RE: Transmission Fluid Type???
ive read that some of the honda transmissions worked with basic motor oil, but you should verify this through your cars booket. Someone on this forum also said castrol syntec wasnt truely a synthetic oil, which i dont know if it true or not, but castrol syntec should be good if your trans actually can use it.
Old Feb 26, 2006 | 10:44 PM
my booklet says that i should use Honda MTF (they just want to make a profit). they said that Motor oil can be used but "should change at earliest convinience). My mechanic said it should be alright though.
Old Feb 27, 2006 | 12:07 AM
marbro's Avatar
yeah, its always best to be safer then sorry, my friends grand am has a hydraulic transmission, he made the mistake of listening to one of the guys at advanced and put mtf in his transmission.... it reeeally screwed things up, he found out after the fact that he could only use syncomesh in it and using that fixed his problems..... for the most part....
Old Feb 27, 2006 | 02:44 AM
lightshow's Avatar
you friend sounds like an awesome mechanic. you should ask him to join this site.....castrol is not a real synthetic oil...because of some loophole they are allowed to print that on the bottle.....i use mobil 1 green top (10w30) .....always....in my tranny and its the original one and i have 250 thousand miles on it......and upshifting or downshifting none of the syncros are even close to being worn out.
Old Feb 27, 2006 | 09:59 AM
RTexasF's Avatar
Super Member
For what it's worth I switched mine to Red Line synth a week after I bought it......couldn't be more pleased. Did the same with the previous car and it made the notchy Mazda 5 speed a lot smoother and more positive shifting, regardless of the temperatures outside.
62maxx
Oct 18, 2015 08:20 AM
JJC
May 21, 2013 09:57 AM
MessAround
Aug 13, 2011 09:45 AM
jdmjnky
Sep 21, 2010 11:21 AM
jq_quint
Oct 12, 2009 02:49 PM
