transmission problem
Old May 16, 2014 | 08:47 AM
adammawyer's Avatar
Default transmission problem
I changed my passenger side rotor on my 96 Honda accord and drove it down the road. While driving I heard a wearing/growling noise coming from the front passenger side. When I got back home I thought the breaks were scrubbing but realized I didn't have the axle nut completely tightened so I tightened it all the way down and drove the car again realizing the noise was still happening. I then changed the Cv axle and the problem still exist. I jacked the car up and it sounds like the noise is coming from where the axle goes into the transmission. Have I completely scewed up my transmission or is there a cheaper fix? Any advice would be greatly appreciated.
Old May 16, 2014 | 10:25 AM
How far away from "completely tightened" was that axle nut? Was it perhaps just the final tightening to final torque that you missed? Or was it 2 or 3 complete turns away from being tight?
Did you remove the axle from the transmission during your brake work?
Old May 16, 2014 | 11:20 PM
adammawyer's Avatar
It was about 2 turns from being tightened. I have heard that the bearings in the transmission might be ruined and that it would cost a lot to fix?
Old May 19, 2014 | 10:58 AM
Jack it up & try to pinpoint the sound.
What I'm thinking is that without the preload (from the axle nut) it seems more likely to damage the wheel bearing vs damaging the transmission.
Still, I can't hear it from here, so rely on you to pinpoint the location.
Old May 20, 2014 | 12:28 PM
adammawyer's Avatar
It is coming from where the Cv axle goes into the transmission. A guy at work said that there are bearings in the transmission but when it comes to transmissions I am lost.
Old May 20, 2014 | 01:38 PM
He's correct, there are bearings in there. I was hoping you were lucky and it was a wheel bearing...
The axle is designed to compress in & out a little bit, so it seemed like a loose axle nut was not likely to cause that damage. Of course that's not an absolute promise...
trouble
Aug 21, 2012 07:46 PM
MessAround
Aug 13, 2011 09:45 AM
mamarotta
Nov 13, 2010 11:10 AM
kellysa111
May 1, 2009 08:35 AM
Krashnpa
Jan 15, 2006 12:57 PM
