underdrive
Old Aug 11, 2007 | 03:41 PM
dan_o_89_rs's Avatar
Default underdrive
does anyone make underdrive pulley's for the 03+ 2.4L?
i found a set on unorthodox's site for "04-06 ACURA TSX 2.4L DOHC 16V."
Old Aug 19, 2007 | 04:01 PM
Default RE: underdrive
does anyone know if the acura version of the 2.4 has the same belt set-up as my honda 2.4? (basically will it work on my 2.4)
seems like i read that the acuras have more valves because the v-tech on acuras engage a second set of intake and exhaust valves... does this make the belt setup any different?
Old Aug 23, 2007 | 11:10 AM
falkore24's Avatar
no signature, no help
Old Aug 23, 2007 | 05:30 PM
woops. i tend to forget to check that box before i post.
i emailed mike at unorthodox. here's his reply:
We have had a pulley set available for some time now. It’s the same as the rsx type s kit. Part # 04.06.022.02.
mike
$348.91 for underdrive kit. theres no oem size kit.
thats clears it up for me, and maybe someone else too.
Old Aug 23, 2007 | 05:54 PM
i looked up the weight of these compared to stock, for a 02-05 tsx 2.4l 16v. the differences are pretty cool.
Weight Comparison
Old Aug 24, 2007 | 09:05 AM
falkore24's Avatar
The pulleys are great, but without I/H/E you can't rev up that fast to take advantage of them. They'll help some by reducing parasitic inertial drag, but their effect is noticed as you run higher rpms. Without the I/H/E, your rev moves slower so your avg. rpm is lower. I'd look into headers if I were you.
srpowersuw
Mar 23, 2008 03:26 AM
frankiexthedork
Sep 14, 2007 07:54 AM
joe592
Aug 22, 2007 05:04 PM
snoopydapimp
Aug 20, 2007 02:14 PM
trojanhorse
Jul 26, 2007 04:56 PM
