Valve chatter?
Old Jun 23, 2008 | 10:40 PM
clutch811's Avatar
Default Valve chatter?
my accord has the f22b2 engine and has 185000 miles and i notice that the valves tend to chatter. best description. is this a clearance problem and can be adjusted by a mechanic or maybe another problem.
Old Jun 23, 2008 | 10:50 PM
nafango2's Avatar
Default RE: Valve chatter?
you can check the clearances yourself with a set of feeler gauges (<$10), a set of mm wrenches, and a flathead screwdriver. check the diy section.
Old Jun 24, 2008 | 12:25 AM
Adjust every 100k miles or sooner if they make noise.
jfidelh
Feb 26, 2013 10:03 AM
joj73
Nov 28, 2012 05:19 PM
joj73
Apr 7, 2012 02:49 PM
19962door
Oct 3, 2007 02:50 PM
importnewbie
Aug 10, 2007 08:48 AM
