Valve space
Old Feb 21, 2008 | 11:54 PM
johnraven3000170
Default Valve space
I have a 94 Honda accord. How do I check the space between the vavles and how do I adjust it?
Old Feb 22, 2008 | 11:45 AM
Default RE: Valve space
You mean check & adjust the valve clearance?
Each valve rocker (#1, 2, 3) has an adjusting screw (#9) & locknut (#15).
You should get a shop manual for a proper procedure. Maybe there's a summary in the DIY section here, but you can do the searching...
Cliff notes...
First turn the crankshaft (forward only) until each cylinder in turn comes to top of it's compression stroke. Measurement is only valid at that position.
You measure with a feeler gauge underneath #9 where it pushes against the top of the valve. Measure when it's at room temperature because Honda publishes the clearance at room temperature. The proper clearance is probably listed on a sticker on the underside of the hood.
KO23
Aug 25, 2012 10:49 AM
lead foot mcgee
Mar 9, 2011 10:11 AM
racso9018
Aug 10, 2009 11:02 PM
Audioz
Dec 16, 2006 01:01 AM
Trav20
Oct 15, 2006 04:03 AM
