Vtec Engine
Old Oct 8, 2011 | 08:22 PM
drumdoctor's Avatar
Default Vtec Engine
If I have a 1999 2.2 Vtec engine and the only thing that the engine is running is the alternator---plus there is a performance intake, headers and an oil cooler,will I see any increase in performance and/or gas mileage?
Thanks.
Old Oct 9, 2011 | 06:41 AM
Some performance gain, porb not much.
Gas mileage, I don't think that will increase.
Old Oct 9, 2011 | 10:52 AM
g22cd5's Avatar
Supper Moderator
with the P/S and A/C not running off the engine you didn't gain any power you just simply free up lost power that the A/C and P/S where using.
As your header and intake you might have gained 4-5hp at most. If you want to see little bit better gains you will want a tune. A simple street tune will work you don't have to shell out the big bucks for dyno turning since you don't have too much really done to your engine.
Old Oct 9, 2011 | 12:53 PM
drumdoctor's Avatar
Default Tuning
What does a "Street Tune" consist of?
Thank you.
Old Oct 9, 2011 | 09:07 PM
piggylover1985's Avatar
I don't think you can do a simple tune to the car since it's OBDII, Also for just only the header and intake you can get away without tunning, but you might not see the full "gain" in hp, mine 99 with intake and full aftermarket exhaust without tuned still did good on dyno, and the A/F is good all the way to red line without wide band controller.
Old Oct 10, 2011 | 09:43 AM
g22cd5's Avatar
Supper Moderator
a street tune is where the tuner rides in the car with you and adjusts your Air Fuel ratio to your driving habits. When having a intake and exhaust on stock ecu you end up running rich (that why you see hondas with big black spots on the bumper where their muffler comes out) At the point you can save a little bit of gas mileage b/c your tuner can tune you not to run rich and run a good a/f ratio. Like Piggylover said your OBD2 so you might have to spend a little bit more money to get any type of tune. You would have to buy a chipped ecu and a obd1-obd2 conversion harness.
The OBD2 ecus might compensate better than the obd1 systems will. I'v always used OBD1 so I will have to take Piggylovers word for it.
Old Oct 10, 2011 | 02:38 PM
drumdoctor's Avatar
Thanks a lot. I am learning...However there are words and terms that I will have to look up in order to get the full meaning.
So it sounds like just doing the simple mods that I described , leaving the engine stock is the way to go.
Thanks again for the help.
trukid21
May 4, 2012 02:44 PM
cg31998
Dec 15, 2010 10:29 AM
FarRockAccord
18
Feb 1, 2008 06:36 PM
94coupeaccord
Feb 7, 2007 05:01 AM
