weird tranny response
Old Sep 19, 2007 | 09:07 PM
noboundaries6289's Avatar
Default weird tranny response
hey all, my auto tranny is acting a little funny. I can shift from 1-2-d3-d4 fine at low RPM. But when I start to get in the higher range (4k-6k), 1-2-d3 do fine, when I engage d4, it goes into nuetral for just a brief second, then does into 4th gear. At low rpm it's fine, at high rpm it slips a little i guess. Anyone know whats up with my slush box? Could a tranny flush do anything to help it?Maybe a tranny cooler? idk. Thanks ahead of time.
Old Sep 20, 2007 | 09:31 PM
nafango2's Avatar
Default RE: weird tranny response
when did you last get the fluid changed?
did you use honda OEM fluid?
Old Sep 20, 2007 | 10:19 PM
falkore24's Avatar
Mine does the same thing ..... I just chalk it up to the POS tranny that my car has ...... yours was made better.
Old Sep 21, 2007 | 10:29 AM
00AccordLX5spd's Avatar
Registered User
Do not ever do a tranny "flush".
Drain the fluid once, refill, drive car for a few minutes; drain fluid again, refill, drive car for a few minutes; drain fluid again, refill. That is the procedure for changing your trans fluid.
Only about 1/3 of the fluid comes out per drain, that's why you got to do it 3 times.
Old Sep 24, 2007 | 10:50 AM
I havn't touched the tranny fluid since I got the car. It is still orange lookin, so i assume it's still good. AAMCO seconded me on that. If I do get my tranny fluid changed, where's the best place to do it? Honda dealership?
Old Sep 24, 2007 | 11:45 AM
falkore24's Avatar
As long as Honda ATF is used, it really shouldn't matter who does the change. I think that I figured out what causes the 3-4 gap in the gear change. I think that the gap might be the lock-up solenoid releasing the torque converter. Our trannies don't lock up in first or second gears which would explain that it is only the 3-4 shift. The lock-up function basically makes the fluid connection that is the torque converter into a solid connection, eliminating the torque converter's function at high rpm's. This gives a little more power and efficiency.
Old Sep 28, 2007 | 01:29 PM
wow...thanks a bunch!
Pat61
Apr 20, 2012 03:21 PM
tqriddle
Aug 22, 2009 05:14 PM
Ronnie101
Nov 23, 2007 04:12 PM
nwurts
Jun 27, 2005 03:03 PM
