whats the difference? Whats better?
Old Feb 22, 2013 | 10:11 AM
firefighter44's Avatar
Almost A Senior Member
Default whats the difference? Whats better?
As the title suggests, Im wondering what the difference is between the h22b1 and the h23a1? Also which is "better"? Upon brief visual inspection the only difference i saw was a little difference in the intake manifold. They are both vtec 4 cylinders, so whats the difference
Old Feb 22, 2013 | 11:48 AM
H22b1? You mean f22b1? Or h22a1?
Old Feb 22, 2013 | 03:15 PM
oh mis typed i meant f22b1 and f23a1
Old Feb 22, 2013 | 04:32 PM
F22b1:
Bore × Stroke: 85.0 × 95.0 mm
Displacement: 2156 cc
Compression ratio: 8.8:1
Valve Configuration: SOHC, 16 valves (4 valves per cylinder), VTEC
Max power: 145 hp (108 kW) @ 5500 rpm
Max torque: 147 lb·ft (199 N m) @ 4500 rpm
F23a1:
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 150 hp (112 kW) @ 5700 rpm
Max torque: 152 lb·ft (205 N m) @ 4900 rpm
Pretty much just .1L and a little bit of power.
Old Feb 22, 2013 | 06:38 PM
oh ok, Thanks live
CP1
Nov 30, 2012 10:21 AM
mamtsberg
May 22, 2007 03:09 AM
randomname67
Sep 5, 2006 11:13 AM
06v6
Jul 4, 2006 04:04 PM
