Wheel locked and ABS indicator ON
Old Dec 22, 2008 | 01:13 PM
vishalsthakur
Default Wheel locked and ABS indicator ON
Hello Experts,
I have an Accord SE 2006. Recently, we had lot of snow. In the snow, my left rear wheel gets locked (does not rotate) and I get the ABS indicator on. When the snow melts and things are normal, these two problems don' exist.
Does anyone know what may be the problem?
Old Dec 22, 2008 | 04:01 PM
Default RE: Wheel locked and ABS indicator ON
What causes the wheel to lock?Is the brake dragging?
If so, fix the dragging brake first & see whether the problems go away.
Old Dec 23, 2008 | 02:04 PM
vishalsthakur
Hi Jim,
Thanks for your reply. How do I find out what's happening? But I can give you my observations:
1. Only the left wheel is locked.
2. My hand-break feels quiet loose. I mean from its normal position when I pull it up, it feels loose and only when I pull it harder it seems to brake.
3. A little motion is still there in the wheel like a freeplay of the wheel. But beyond few inches of free play it gets locked.
I contacted the dealer and he is saying that if the ABS and wheel lock is not due to current whether conditions, then it may be covered by Mfg. warranty. For your information, I am in Portland, OR and we have recently received a lot of snow and freezing rains and freezing temperature. Does these kind of problems common due to weather?
Please let me know.
Old Dec 28, 2008 | 10:37 PM
When its NOT full of snow, lift that corner of the car. Spin the wheel & check for friction from the brake. If youre not sure, compare it against the other side.
Maybe try the same thing when it IS full of snow. Just be careful about things sliding around. Support it propery & dont let the car fall on you...
My GUESS is the brake is dragging enough to lock it in snow, but wet & dry roads provide enough force to roll the wheel in spite of the dragging brake.
L2_DJ
Oct 20, 2013 08:45 PM
Mic-Ill
Feb 9, 2013 02:36 PM
Spinninwrenches
Dec 8, 2011 01:14 PM
snoepybell8
Feb 7, 2011 06:12 PM
SirJohnIII
Dec 13, 2010 01:32 PM
