[92 ACCord EX] California Smog Issues and ABS Issues
Old Jan 20, 2012 | 02:22 PM
ABS fluid reservoir should be translucent, so with the right light you should see the fluid level just like your main brake-fluid reservoir. (wipe the crud off the outside of the ABS reservoir)
Old Jan 20, 2012 | 03:34 PM
Ineedhelp's Avatar
Ok I wiped the crud off and found just the opposite of low.
The Reservoir has a Max Line about half way up the Reservoir and the fluid level was up to the top of the Reservoir. What does that mean.
Old Jan 22, 2012 | 07:29 PM
That probably means someone over-filled it. But that doesn't rule out the possibility that there's air in the ABS modulator, or for that matter air in the main brake system. Bleed your brakes & see whether that helps.
93Accord2.2
Nov 7, 2013 07:10 AM
lxv5
Nov 16, 2011 09:58 PM
retprep
May 12, 2011 10:03 AM
jbeezy53
West
May 6, 2010 01:27 PM
DKYamada
Mar 6, 2007 02:22 AM
