'00 Accord radio/CD
Old Apr 28, 2007 | 06:56 PM
choffman41's Avatar
Default '00 Accord radio/CD
My '00 Accord has the standard (I guess) AM/FM/Cass radio with a separate CD player under it where the little tray goodie would go. The CD (single) player is getting goofy and I don't want to mess with it. I am considering a "premium" 1 piece unit from a more expensive Honda to drop in. Are the wiring harnesses compatible? I know I will have to have the theft code for it. I am looking for a simple bolt in setup without any mods. May also consider one of the 6 CD changers that will fit the hole if the harness is compatible. Thanks...
Old May 6, 2007 | 01:24 AM
choffman41's Avatar
Default RE: '00 Accord radio/CD
O.K. then, I'll answer my own question after considerable research, for the good of the order. It appears that the wiring harness plugs are compatible for most Hondas from 1998 forward. Also, if you have a separate single CD player under the radio, you can slip in a 6 disc changer (in dash type) as a replacement. Looks like the higher dollar stereos also fit right in wire-wise, but don't forget you will need the theft code.
djaycardona
Nov 26, 2013 04:07 PM
GMANCRX
Jul 15, 2013 02:50 PM
RecMK5
Feb 13, 2009 06:33 AM
Jeff247
Mar 28, 2007 04:22 PM
gdr_11
Apr 7, 2005 08:58 PM
