01 Accord Coupe No flash or honk
Old Jun 9, 2014 | 12:18 AM
Benitezedwin5's Avatar
Default 01 Accord Coupe No flash or honk
So my 01 accord coupe doesn't show flash or honk when I lock the door. And the led alarm doesn't go on by the door. My panic button works.Someone please help me
Old Jun 9, 2014 | 12:43 AM
Welcome to the forums..Someone will be along who knows about your problem soon.
Thank You for joining the HAF..
Old Jun 9, 2014 | 12:50 AM
Thank You
Old Jun 9, 2014 | 12:56 AM
Just to confirm, which it sounds like, this an EX trim level with the factory alarm?
Is there anything else electrical, other than the security system not working? If there is something else electrical not working, then this may indicate a possible fuse issue.
Otherwise, for the system to arm, the ignition switch must be off, the key must be removed, and the security control unit must receive signals that the doors, hood, and trunk lid are closed and locked. If one of the switches is misadjusted or there is a short in the system, the system will not arm. As long as the control unit continues to receive a ground signal, it senses that the vehicle is not closed and locked, and the system will not arm.
Old Jun 9, 2014 | 01:25 AM
Everything Electrical works, it is and EX with Leather and everything is closed (hood,trunk, doors). When i unlock the doors, the car light flash twice but it doesnt do that when i lock it. It is factory alarm. If it is the fuse, which fuse should it be? And if its the alarm, where could i check the connections? Thank you for replying too!
ColdPhire
Feb 20, 2008 11:01 PM
pham9006
Feb 12, 2008 04:29 PM
kreizyidiot
May 25, 2007 11:19 AM
rmistry7
Jan 26, 2007 08:13 PM
