02 Accord EX electrical problem?
Old Dec 12, 2017 | 09:52 PM
Gavin Tracy's Avatar
Question 02 Accord EX electrical problem?
Hi I recently just bought an 02 Accord EX v6. 90k miles and every one or two times I drive it the lights and heat have lost some power but not all for just a second or two. Sometimes repeatedly every minute or 2 repeated for several times and other times only once. In both warmer and colder weather. Not sure if this is a problem i should get checked out, it has a new battery the car is very well maintained just not sure why it would do this. Thanks
Old Dec 13, 2017 | 06:14 AM
So things keep running, but the lights dim and the blower slows down for a second or 2?
Is it throughout the car? Then maybe a battery connection is loose, dirty, corroded, etc. Check the clamps on the battery posts, but especially check the OTHER end of each battery wire. I don't know the details of the connections at the fusebox, but there's 1 or 2 large fuses that are installed with screws not push-in.
If it's limited to a few systems, that might help pinpoint places in the wiring harness like specific grounding points for you to check & clean. Pretty mush the same fix as above, but knowing which things lose power will help you search for the culprit.
TRIGGA
Oct 19, 2007 01:57 PM
roadman1977
Dec 30, 2006 04:37 PM
SnowDog1026
Dec 26, 2006 01:16 PM
eddyfurukawa
Feb 13, 2006 03:15 PM
qbtarget
Feb 13, 2006 01:56 PM
