02 Accord LX 2.3 4 cyl grinding issues
Old Dec 28, 2024 | 02:52 PM
KED1112's Avatar
Default 02 Accord LX 2.3 4 cyl grinding issues
I am having a loud grinding sound that sounds like it is coming from the middle of the engine bay. I just replaced the CV axles, and there are no brake or wheel bearing issues. The grinding gets louder as I accelerate, and it grinds in N and Reverse. I also just had a grinding sound putting the car in park yesterday for the first time ever. If anyone is experienced enough to comment on whether this could be a differential issue, possible input shaft bearing, pinion seal, or anything else I am not thinking of I would appreciate it.
Last edited by KED1112; Dec 28, 2024 at 03:18 PM. Reason: mis spel and added something
Old Dec 30, 2024 | 10:30 PM
Check the installation, but you could have a bad CV joint out of the box?
Old Jan 7, 2025 | 03:07 PM
kris_loehr's Avatar
If I remember right there is a transmission part that causes the noise when you put it in park and it come from going from reveres to drive while the car is still moving.
Old Jan 7, 2025 | 06:18 PM
nomad2020's Avatar
Did the noise start after you replaced axles?? If it also grinds in neutral I am assuming car is not moving so,I would have to exclude a bad axle , possibility the axle is not all the way in the tranny???
Old Jan 10, 2025 | 05:00 PM
Autotecnica Support's Avatar
What happens if you jack up one front wheel at a time and put the car in neutral, and turn the wheels by hand so you can listen to the rubbing without engine noise?
KED1112
Dec 27, 2024 07:55 AM
modernmilitia
Nov 5, 2013 01:19 PM
streetroc85350
Jan 22, 2013 09:49 PM
K_D_M_69
Nov 11, 2010 03:41 AM
amyandrew2
Apr 15, 2006 03:40 PM
