98 LX AT with a "whine"
Old Nov 4, 2013 | 05:56 PM
modernmilitia's Avatar
Red face 98 LX AT with a "whine"
i am a decent mechanic, been doing it for decades, but this one has me a tad lost. this 98 LX with the AT has a bad, loud moaning "whine" from about 20 mph on up. tone and pitch change when turning the car. first thought was CV's...visual check showed a cut boot and grease loss so...passenger side half-shaft replaced with new. sound didnt change. on the word of a "realy good Honda guy" i had the front wheel bearing replaced....sound didnt change.
does the "carrier" bearing on the pass. side have a history of going bad?
thoughts?....
is there a known "whine" that will come from this trans?....trans fluid has been changed with Honda fluid...sound almost disappears when turning left gets a tad louder turning right.
any help is much appreciated
Old Nov 4, 2013 | 06:15 PM
Damaged carrier bearings are a known problem on the 6th generation Accords.
However, if there is a sound, it is usually described as a load moan or roar.
Here's a little info. (see attached).
Attached Thumbnails 98 LX AT with a "whine"-6th-gen-accord-carrier-bearings.jpg
Old Nov 4, 2013 | 06:17 PM
Roader's Avatar
I've heard of carrier bearings getting sloppy to the point that the seal leaks, but never noisy. Doesn't mean it can't happen. Put the front end up on jackstands, have a helper start the car and put it in gear, and try to pinpoint the noise. A stethoscope or a big screwdriver is helpful. Keep hair/clothes/fingers away from rotating stuff.
Old Nov 4, 2013 | 06:56 PM
thanks for the responses...more confuddled now...i guess im using the wrong name for the suspected part...the passenger side drive shaft has a "mid shaft bearing" and this is what i am suspecting BUT it is "tight". this was the bearing i was referring to....if it is the "carrier bearing" is that a "remove the tranny" job?....
Old Nov 5, 2013 | 01:19 PM
Roader's Avatar
Yeah, but don't jump to conclusions. You can find the names of parts at Honda parts websites. Sons Honda is the easiest to navigate. I think the bearing you see is called the half shaft bearing. I have zero experience with them because my car doesn't have one, but I'm guessing it could whine when it fails. Pinpoint the noise or have a mechanic do it if you're uncomfortable getting underneath your car with the engine running and the trans in gear.
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
Jon B
Jun 18, 2006 04:36 AM
