02 Accord V6L ECU problem - Please Help
Old Nov 1, 2010 | 08:38 PM
australi's Avatar
Smile 02 Accord V6L ECU problem - Please Help
Hi, I own a 02 Accord V6L. A very good car, comfortable and all that.
However, the yellow ECU light came on and when I took it back to the Honda Dealer, they ran some diagnostics, and I was told I need to replace the ECU unit . The cost is around AU$2,300. At times the red SRS light also comes on as well.
I understand this model was manufactured in USA. I live in Australia. I have tried to source a 2nd hand unit from Australia, however, there are not that many cars of this model that is wrecked. Hence, none of the wrecker companies can help me.
Can someone recommend a fix for me, Thank You. Alternatively, I am hoping someone can recommend where (in USA) I can purchase a 2nd hand unit of the ECU.
  1. Car Details: 4 door 2002 Accord V6L
  2. Mileage: 57,000 km
  3. VIN: MRHCK16502P040251
  4. Eng No: J30A1-5900300
Thank you
Old Nov 2, 2010 | 05:32 PM
Can you get the OEM part number for your PCM? If that part number is the same as one of the US made PCMs, then you can order from a junkyard (car-part.com) or Ebay.
You will have to see if they will ship it to Australia for you.
Old Nov 2, 2010 | 07:20 PM
First I would want to be sure the ECU is bad. Check Engine Light (CEL) on does not indicate a bad ECU,...most of the time. I would suggest getting someone to download the OBD2 codes for you or buy an inexpensive code reader, generally $50-$100 US.
I believe the Obd1 codes are readable on an 02 (and later) Accords. You have to short across pins 4 & 9. See following url ("forums.clubrsx.com/showthread.php?t=636707"). CEL will flash OBD1 codes (long flashes=10 and short flashes=1). Note this will also allow SRS codes to be read. See link for details. If you have any troubles, PM your email and I'll forward a PDF of this for you to use.
If CEL produces real codes I would be inclined to run them to ground before pursuing ECU replacement.
Old Nov 7, 2010 | 05:21 PM
australi's Avatar
Default Thank you for reply
Hi,
The part number of the ECU is 37820 P8C Q52
I will show the advise to the technicians to check.
Thank you for the reply..
Australi
Jae Min Chang
Sep 17, 2013 04:23 PM
live2rice
Sep 20, 2012 02:26 PM
94AccordEXThesleeper
Dec 13, 2010 08:08 AM
codex515
Jun 18, 2009 07:24 AM
hurraquio
Dec 7, 2007 02:09 PM
