02' Brake Light Replacement Help!
I have a 02' V6 Accord 2dr coupe and my left break light is out. I know this is way simple but I can't figure it out and I don't have the owner's manual. I bought the bulb just need help putting it in. Thanks in advance!
It appears that you have to remove the trunk trim (carpet stuff) and completely remove the tail light assy from the whole car just to change the bulb, do not overtighten the nuts when you put it back together. Also make sure you have the same number bulb, you may get a bulb check light if you put in a non specific bulb for your car.
ORIGINAL: 2POINTautO
Mitchell on Demand says go the long route, let me pull up your year model and check the directions.
EDIT
I think I need to get my glasses checked, pull the carpet back and maybe you can change the bulb, there are no directions for that, is there not a small cut out directly in front of the tail light assy to change the bulbs, the carpet may just flip up. I may have a reference for an owners manual. I will go check that now too.
EDIT
victorywhity
Mar 24, 2011 09:37 PM
wize_n
Oct 10, 2008 06:49 AM
