03 accord oil issue
2003 accord LX with 104,500 miles
I am loosing oil. (within 1200 miles of oil change - full to less than quart) The check oil light does come on, especially when I brake hard or fast. I turn off and re-start engine and the light goes off
There is no spotting on the driveway, nor burning smoke. There is stainage on the engine (left side if looking at it)
I took it to two different places. One had no explanation, the other "thinks" its a gasket issue and could cost $350.00
Other than taking to Honda, anyone else have this problem?
thanks in advance.
thanks in advance.
welcome to forum
clarify - is this right?
~4qts oil capacity at change and you lose 3 qts in 1200 miles?
generally, beyond big drip evidence, I'd have someone else drive it and you follow behind to observe.
but maybe you've done this.
best
best
if it's not leaking, it has to be going somewhere, that's excessive for 1200 mile...have you pulled the plugs and checked condition? my 03 2.4L with 180k, uses about a quart every 2500 miles or so. something is wrong....
most of us with oil problem would check oil frequently and add when it reaches 1/2 qt lower than full.
Sounds to me like it's normal operation is maybe 2 qts low.
Checking out - don't think I can add anything.
To me it sounds like there's a little oil on the tip of the dipstick when he checks it cold. That's a bit low, but I don't have the 2003 car any more. Seems to me the dipstick has a couple mm extra length below the "low" mark. So maybe it's a pint below the "low" mark. Need to add oil but maybe don't need to panic about damaged engine.
art vandelay
Aug 2, 2010 09:29 AM
