03 headlight
Old Nov 5, 2008 | 12:41 PM
mr.crown's Avatar
Default 03 headlight
hey u guys whats up i am the new owner of a 03 accord coupe and unfourtunately ive had the car for 3 days and just realized my passenger side headlight is burned off its such a tight space i really dont know how to get to it HELP!!!
Old Nov 5, 2008 | 12:50 PM
falkore24's Avatar
Default RE: 03 headlight
ORIGINAL: mr.crown
Like someone hit it with a cutting torch? If you mean that the bulb is dead, you have to just deal with the tight space ..... maybe there is something that you can remove to help with access. On my 2000 V6, the battery could be moved to allow space to the driver's side high beam. On the Scion, the coolant overflow gets removed to get to the driver's side highbeam. Also, a Z-driver can help loosen the screws that hold the base of the bulb. They don't get removed and really aren't supposed to be touched, but loosening them 1/8 of a turn helps get the bulbs in and out.
Old Nov 5, 2008 | 01:09 PM
mr.crown's Avatar
lol yeah sorry i mean the bulb burned out so are the screws suppose to come all the way out then???
Old Nov 5, 2008 | 01:18 PM
finch13's Avatar
From what I've heard, the 7th gen (2003-2007) headlights bulbs are one tough cookie to replace. Since you just bought it, a good investment would be a Haynes service manual.
Old Nov 5, 2008 | 01:38 PM
mr.crown's Avatar
yeah my thoughts exactly but i was wondering if driving with the hi-beams on at night for a couple days gonna cause me problems???
Old Nov 5, 2008 | 01:41 PM
finch13's Avatar
Yes, because high beams are for driving on dark roads alone at night. You can drive with one headlight, yes? Or not drive at night, yes? You can get ticketed for failing to turnoff your high beams.
Old Nov 5, 2008 | 01:42 PM
mr.crown's Avatar
yeah on the flip side i just wanted to avoid the fix it ticket for driving with only one light but thanks this is gonna be tricky
Old Nov 5, 2008 | 01:46 PM
finch13's Avatar
why don't you go to the store now and pick up a bulb... put it in and be on your merry way?
Old Nov 5, 2008 | 02:40 PM
falkore24's Avatar
the screws aren't meant to come out. They are the fixture, just that loosening them a bit makes the bulb change easier. You just have to work on it for a while.
Fez
Mar 10, 2007 05:01 AM
05accord
Dec 2, 2005 09:22 AM
#1hondaaccord
Oct 5, 2005 04:12 AM
WyDubbs
Mar 21, 2005 04:34 AM
