04 Accord front brakes lock up-Need Info?
Old Dec 1, 2014 | 10:50 AM
billthomp7's Avatar
Default 04 Accord front brakes lock up-Need Info?
I was checking fluids and I though the Brake fluid looked a bit low. So I add some (to much) and now when the brakes heat up (5 min or so) they start to lock up. They get worse as they get hotter. The Brake peddle is very hard. It maybe back brakes as well. They were just fine before I decided not to leave well enough alone. Thanks for any info
Billthomp7
Old Dec 1, 2014 | 10:55 AM
Get something like a turkey baster to remove some from the reservoir. Then get the brake pads checks, they may be worn down. The fluid level in the reservoir drops as the brake pads wear down.
A leak will also cause the fluid to drop; however, a leak usually is visible if that were to occur.
Old Dec 13, 2014 | 12:54 AM
Hey..missed your 1st post..Welcome to the HAF..
Old Dec 28, 2014 | 03:36 PM
Talking Hey RedBull1
Do you think he-she! ever took your suggestion and tried your post?
Maybe they will come back and respond to you..
Happy Holidays RB1..
Attached Thumbnails 04 Accord front brakes lock up-Need Info?-happy-new-year-hd-wallpaper-2015.jpg
Old Dec 28, 2014 | 03:41 PM
Not sure whether the OP took the suggestion. Not a safe situation to leave.
Happy Holidays Ang.
Old Dec 28, 2014 | 03:54 PM
Talking
Happy Holidays Ang.
Same to you buddie..
alphaney
Feb 12, 2022 10:14 AM
adamsnorth
Jan 2, 2010 05:49 PM
graywraith
Aug 22, 2007 09:43 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
