Brakes lock up - 2000 Honda Accord
Old Aug 22, 2007 | 06:43 PM
graywraith
Default Brakes lock up - 2000 Honda Accord
I have a 2000 Honda Accord 2 Dr and my car has developed a strange problem. I will be driving the car for about 15 - 20 minutes and then all four brakes will lock up. The way to describe what happens is that it feels like I am depressing the brake pedal and then pressing the gas at the same time. I can get out of the car and touch the brakes and they feel like they are getting really hot. This happened on my way to work today and I had to keep going because I was on a busy part of the freeway with no shoulder. After about 10 minutes, everything returned to normal. I got to work and went about my day. After work, this same thing happened and once again after 10 minutes, everything went back to normal. Could this be a sign that the master cylinder is going bad or could it be something else?
Thank you in advance.
Old Aug 22, 2007 | 08:06 PM
deserthonda's Avatar
Default RE: Brakes lock up - 2000 Honda Accord
i have seen this happen quite a few times after the brake master cylinder has been replaced with some cheap part,,
have you replaced the brake master anytime in the near past ???
if yes ,, install a Honda part
if no, first bleed the system, then chk the brake master push rod lenght ..
Old Aug 22, 2007 | 08:29 PM
graywraith
I had a brake job ( pads and rotors) done a couple of months ago, but did not have any probems until now.
Old Aug 22, 2007 | 09:24 PM
to have all the brakes lock up ,, it has to be an issue with the brake master ,, contaminated fluid,, faulty master ,, take it back and have them chk it out ...
Old Aug 22, 2007 | 09:29 PM
graywraith
Thank you very much for your input. I will do that.
Old Aug 22, 2007 | 09:37 PM
has anyone replaced brake fluid in your car recently ??? I remember of a shop that put the wrong fluid and has the same issue as yours .
Old Aug 22, 2007 | 09:41 PM
graywraith
Not unless the shop that did the brakes did. I will have them double check that.
Old Aug 22, 2007 | 09:43 PM
please let us know i am curious ,, plus it would be a good thing for other members to know what the fix was
alphaney
Feb 12, 2022 10:14 AM
billthomp7
Dec 28, 2014 03:54 PM
Doublel
Mar 11, 2013 07:57 AM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
