04 accord starting issues
Old Apr 30, 2016 | 06:23 PM
Starter Cut Relay is in the under dash fuse relay box. See attached diagram.
Old May 1, 2016 | 06:42 AM
You are on the right track. When you spayed the ether did you open the butterfly on the throttle body and get it inside the intake?
Old May 1, 2016 | 11:53 AM
Hon Da Road's Avatar
No but I will today. I am concerned that with my old ignition it would turn over and start but only 1 out of 10 times but with the new ignition it just turns over every time I turn the key but wont start at all. Its like I switched problems when I changed the ignition switch cylinder,
Old May 1, 2016 | 03:30 PM
I opened the butterfly and hit the intake with the ether it just turns over it sounds electrical .
Old May 1, 2016 | 06:06 PM
Your original post was from august 2015. Sounds like the electrical portion of the ignition switch solved your original problem with the starter.
How long was the starter working properly before the new issue where the engine won't run on its own occurred?
Old May 1, 2016 | 08:37 PM
No starter problems the noise was coming from my cut relay after trouble shooting thanks to TexasHonda i found it was my ignition switch but after replacing it now the new problem is it just turns over like its not getting spark.
Old May 1, 2016 | 10:49 PM
  #17
How long was the starter working properly and the engine running properly before the new issue where the engine won't run on its own occurred?
Old May 3, 2016 | 10:23 AM
  #18
IT wouldn't start for about a month with the old issue i replaced the switch and the new issue started im wondering if theirs something with the new switch or a new problem problem accrued. The new switch was used from the junk yard.
Old May 3, 2016 | 06:00 PM
  #19
Now that the starter is working properly, you need to figure out if the engine is not starting due to lack of spark or lack of fuel.
The first thing I would do is check for engine codes, if you have a scanner.
If not, then you will need an old spark plug to test for spark.
Does this vehicle have an aftermarket alarm system installed?
mjb
Oct 15, 2009 06:26 PM
justincollier
Sep 11, 2008 09:33 AM
cumminsman
Feb 13, 2008 12:09 PM
Slowaccord
Aug 28, 2007 08:38 AM
MRMASON
Oct 3, 2006 07:09 PM
