04 honda radio/clock issues
Old Dec 27, 2010 | 03:09 PM
jeaner's Avatar
Default 04 honda radio/clock issues
My factory installed radio/clock stays on all the time- even when there is no key in the ignition & veh is off & locked! Any ideas what it could be??
Old Dec 27, 2010 | 03:52 PM
Does anything else also stay on, such as power windows, etc.?
Old Dec 28, 2010 | 03:29 PM
jeaner's Avatar
No nothing else stays on- just the clock/ radio cd player...
Old Dec 28, 2010 | 03:50 PM
Since only the radio/clock stays on, I would think this is a problem with the driver's side under-dash multiplexer. This multiplexer is part of the driver's side under-dash fuse/relay box assembly on your car. If other things stayed on, then there is a possibility it could be the ignition switch.
There was a recall on certain Accord's fuse/relay box assemblies due to a stalling/no start safety issue. Let me look if that pertain to the 2004, that way, you may be able to get it replaced without charge.
00AccordLX5spd's Avatar
Registered User
I seem to remember a recall on the 7th gen radios. What I remember though was the screen would become black and unreadable. I know the fix was the dealer would replace for free. How many miles on your car? You could always call a dealer and give them the VIN and ask them if there are any recalls or TSB's on the radio (that would be the first thing I would do anyway.)
Old Dec 28, 2010 | 03:52 PM
IIRC, that TSB was regarding dim or no display, not related to radio staying on. The circuit board would get replaced.
Here is the superseded TSB: driveaccord.net/forums/attachment.php?attachmentid=7096
Old Dec 28, 2010 | 04:05 PM
The fuse/relay/multiplex box assembly recall was only for certain 2005 Accord and Odysseys. So, may not be able to get it replaced without charge.
dvpatel.homelinux.com/forumfiles/SB/A05-014.PDF
Old Dec 28, 2010 | 04:14 PM
If you want to see what the part looks like and see how it is replaced, see this TSB:
hondalac.com/service/Bulletins/x03-029e.pdf
Old Dec 29, 2010 | 11:17 AM
jeaner's Avatar
Thanks a bunch-- I guess I will just contact the dealer to see what they say
mellospace
Mar 27, 2009 08:06 AM
old88dog
Jun 13, 2007 10:58 PM
doctorpowder
Sep 12, 2006 11:26 PM
kramrkixass@yahoo.co
Nov 26, 2005 12:42 PM
gdr_11
Apr 7, 2005 08:58 PM
