05 Accord V6 morning noise
Old Mar 18, 2013 | 08:18 AM
kenpoed's Avatar
Default 05 Accord V6 morning noise
I have an 05 accord with 100k on it. In the morning when cold there is a clicking noise under the hood. After warming up for 10 minutes it goes away.
My local tech states it could be a valve adjustment issue or a fuel injector but to not worry about it. I wanted to know your thoughts.
Also, if I drop off at a Honda dealer for a valve adjustment, how much should it cost? It seems like it would not be a bad idea.
Old Mar 18, 2013 | 10:21 AM
Dr. Drivability's Avatar
i'm going to guess that you have not done the timing belt yet? if that's the case, drop the sheckels and get the timing belt, waterpump and valves adjusted all in the same trip whether to the dealer or indy shop. heck, i'd even go for a new serpintine belt, but that's just me book time labor is about 9 hours at whatever they charge, figure a couple hundred in parts, but if you sneak out for less than 1500 smackers it beats putting a new motor in due to a broken belt.
Old Mar 18, 2013 | 10:55 AM
kenpoed's Avatar
I replaced the timing belt and water pump 10k ago. Is that $1500 estimate including a timing belt? V
Old Mar 18, 2013 | 11:01 AM
good to see someone is keeping up on maintenance. yes, that was with the timing belt. valve adjustment alone would be 4.5 book time plus valve cover gasket set. figure 400-500 bucks. and for what it's worth, injector noise usually won't go away after warm up.
Old Mar 18, 2013 | 11:12 AM
kenpoed's Avatar
Thanks!
Old Mar 18, 2013 | 12:12 PM
A clicking valve that quietens when engine warms is not harmful and will run a long time. I ran a 90 Accord for over 100k that clicked on cold mornings for 5-10 mins then was quiet. If you can't stand the noise, then adjustment should resolve.
brar
Jan 23, 2012 12:28 PM
eberry4
Jan 20, 2012 08:41 AM
9DEX
Jun 2, 2011 01:38 PM
pateati
Jan 10, 2011 03:04 PM
Steve Rosen
Jan 5, 2009 12:30 PM
