05 coupe, passenger window will not budge
Old May 28, 2014 | 08:58 PM
bryyce62's Avatar
Hello,
I have nearly the same problem as the others here. An 05 coupe, passenger window will not budge. I get a click from the drivers door control, that's it. Tried to short the white/green wire to ground and still no help.
Bought a new main control, still nothing.
Any help would be appreciated.
Old May 28, 2014 | 09:24 PM
I copied and created a new thread for you, as your situation is not exactly the same.
Old May 28, 2014 | 09:36 PM
The issue can be due to:
  • Poor ground
  • Blown under-dash Fuse No. 26 (20A)
  • Faulty passenger power window switch
  • Faulty passenger power window motor
  • Open in wire
1. Check the under-dash Fuse No. 26 first.
2. At the 23-P connector for the door multiplex control unit, attach a jumper wire from cavity terminal 9 (Blu/Wht) to 10 (Grn/Wht); and a jumper wire from cavity 3 (Wht/Grn) to body ground. -- The passenger window should go down.
3. Attach a jumper wire from cavity terminal 10 (Grn/Wht) to 18 (Blu/Red); and a jumper wire from cavity 3 (Wht/Grn) to body ground. -- The passenger window should go up.
Report your results.
Old May 29, 2014 | 09:55 AM
bryyce62's Avatar
Thank you. I'll try this today and report.
Old May 29, 2014 | 10:41 AM
This is an image of the location of Fuse No. 26 (20A). If the fuse is blown, only replace with a 20A fuse, do not use a higher amperage fuse.
Attached Thumbnails 05 coupe, passenger window will not budge-interior-fuse-box.jpg
Old Aug 18, 2017 | 07:30 AM
amerc's Avatar
Talking Solution to 3 windows not going down
Hi all,
I have used the information in this thread to open the control unit for the windows ... I noticed one copper track failed the continuity test with corrosion sign (look at the images below). I soldered a jumper wire to correct that and it worked fine.
I have not done the test described above in this thread ... since the symptoms were exactly the same.
Hope this would help others.
Regards
A.C
Attached Thumbnails 05 coupe, passenger window will not budge-control_windows_1.jpg   05 coupe, passenger window will not budge-control_window_2.jpg   05 coupe, passenger window will not budge-control_windows_3.jpg   05 coupe, passenger window will not budge-control_windows_4.jpg
danielwebb
May 27, 2010 01:13 PM
kegwad
Jun 22, 2009 09:20 AM
jaxbrandon
Jul 2, 2008 01:57 PM
wietgr
Nov 22, 2007 10:50 AM
MrGmo
Sep 28, 2007 01:40 AM
