'05 Coupe V6 Manual Misfire
Old Feb 23, 2022 | 09:35 PM
KidCubi's Avatar
Default '05 Coupe V6 Manual Misfire
Hey all,
I ran into an issue a few weeks ago with a misfire in cyl 2,3,5. Replaced plugs and coils assuming that was the problem, everything was fine for roughly 435 miles, then i ran into misfires in cyl 3,5. Just replaced valve cover gaskets and plug tube seals, now I'm down to a misfire in cyl 5 only. You can hear an audible arc somewhere, so I'm assuming it's a wiring issue affecting the cyl 5 coil, but I have no clue where to go from there. Has anyone had a similar issue, or does anyone have any advice on the subject?
Thanks,
Jacob
Old Feb 23, 2022 | 10:32 PM
Since you have an audible arc, start the engine during the night and try to locate the arc. Misting with water may also find the arc.
Old Feb 25, 2022 | 05:02 PM
KidCubi's Avatar
Started it at night, couldn't find anything. In other news, I tried to swap coils and plugs, thinking maybe one is just bad. After starting it up again, I'm back to 3 misfiring cylinders - 2, 3, and 5 like it was initially. Anyone have thoughts on this?
02exv6
Oct 16, 2020 11:30 AM
joshdevries
Feb 23, 2019 03:14 PM
Ryanhmike
Jun 6, 2018 06:12 PM
scomstock55
Dec 17, 2011 04:43 AM
2001SCAccord
Sep 10, 2010 04:15 PM
