06 windshield noise
this is the first I've seen/heard of the issue.... any rain recently? Did you get any moisture inside your car when it rained? feel the molding around the windshield, does it feel loose? (rock side to side etc.)
Check out the plastic cowling around the windshield wipers, or maybe some other stuff down there. Maybe the sound isn't from the glass itself being loose, but something else is rattling around down there. Sound can travel in funny ways thru the solid structure.
I'd be surprised if the actual glass were loose. You may even have some wiring harness between the headliner & roof that has managed to move around a bit.
spray the windshield with the hose and make sure to use hight pressure and go around all of the edges... if water gets in you have a leak obviously if not then there is plastic loose... check the plastic under the wipers and see if you can move your dash at all.... it has got to be something simple.
