06 windshield noise
Old Dec 14, 2006 | 06:25 PM
gaaccord
Default 06 windshield noise
Every time I go over a speedbump or pull into a driveway my windshield makes a sound like it is loose. Does anyone else have this issue?
Old Dec 14, 2006 | 06:55 PM
sir_nasty's Avatar
Default RE: 06 windshield noise
this is the first I've seen/heard of the issue.... any rain recently? Did you get any moisture inside your car when it rained? feel the molding around the windshield, does it feel loose? (rock side to side etc.)
Old Dec 14, 2006 | 07:35 PM
Check out the plastic cowling around the windshield wipers, or maybe some other stuff down there. Maybe the sound isn't from the glass itself being loose, but something else is rattling around down there. Sound can travel in funny ways thru the solid structure.
I'd be surprised if the actual glass were loose. You may even have some wiring harness between the headliner & roof that has managed to move around a bit.
Old Dec 15, 2006 | 03:35 PM
dadams09's Avatar
spray the windshield with the hose and make sure to use hight pressure and go around all of the edges... if water gets in you have a leak obviously if not then there is plastic loose... check the plastic under the wipers and see if you can move your dash at all.... it has got to be something simple.
Old Dec 15, 2006 | 05:24 PM
sir_nasty's Avatar
actually your car is probably under warranty... just make them fix it!
Old Dec 19, 2006 | 10:17 AM
gaaccord
I am going to take it to the dealer and have them figure it out since it is under warranty, I just wanted to see it was something common. Thanks for all the help everyone!
honker3
Mar 1, 2009 03:20 PM
scifiiman
Jul 8, 2006 06:51 PM
joyride
Feb 12, 2006 10:37 PM
luey42n
Nov 19, 2005 09:30 PM
Jirviss
Apr 29, 2005 03:32 PM
