07 accord climate controls stopped working
Old Jan 25, 2019 | 08:23 PM
chriszito81's Avatar
Default 07 accord climate controls stopped working
radio works but climate control doesnt and no lights come on also at the same time my outside temp gage stopped working
Old Jan 25, 2019 | 10:46 PM
ckev70's Avatar
Which model accord? Off hand, check the fuse
Old Jan 26, 2019 | 08:37 AM
2007 v6 auto 4door dual climate control cant seem to find the fuse for the climate control
Old Jan 26, 2019 | 09:39 AM
ckev70's Avatar
It sounds like there is no air coming out of the vents in AC or Heater mode. If this is the case, the heater resistor has failed. Honda calls it a Transistor, Power
https://www.hondapartscheap.com/oem-...QtYXV0b21hdGlj
Image of part
https://www.google.com/imgres?imgurl=https%3A%2F%2Fstatic.burjauto.com%2F image%2F2%2F2518038.jpg&imgrefurl=https%3A%2F%2Fbu rjauto.com%2Fbuy%2F79330SDRA01&docid=iIgzLERNhkp4o M&tbnid=pzzQSsJGcBLEIM%3A&vet=10ahUKEwjK9tuJ44vgAh UorFQKHaSvCaQQMwiAASgCMAI..i&w=800&h=600&bih=698&b iw=1247&q=79330-SDR-A01&ved=0ahUKEwjK9tuJ44vgAhUorFQKHaSvCaQQMwiAASgCM AI&iact=mrc&uact=8
It's located behind the glove compartment on the left. Held by 2 screws and inter screw is difficult to reach due to the position.
There is a way to repair the failed unit but that is another story.
Old Jan 26, 2019 | 09:43 AM
ckev70's Avatar
Image of part
https://www.google.com/imgres?imgurl...act=mrc&uact=8
​​​​​​https://www.hondaaccordforum.com/for...-repair-40796/
Old Jan 26, 2019 | 09:44 AM
ckev70's Avatar
Old Jan 26, 2019 | 09:49 AM
ok ill swap it thanx
Old Jan 27, 2019 | 06:30 AM
i swaped it still nothing
Old Jan 27, 2019 | 09:14 AM
For giggles, do the power mirrors work and or the seat heater?
Really sounds like the #30 under dash 7.5 amp fuse has blown
In the book I have. In the under dash fuse box the top row, 11 slots which may or may not all be used, is numbered #23 through #33 when counting from the left to the right. So again you will be looking for #30 and it should be a 7.5 amp. Again as stated all the slots may or may not have a fuse in it but they do count.....ps in the diagram I have 29, 31 and 33 are not used from the factory.
Old Jan 27, 2019 | 09:35 AM
fuse #30 7.5 is ok and power heated seats and mirrors work
