07 accord climate controls stopped working
Old Jan 27, 2019 | 09:39 AM
chriszito81's Avatar
the outside temp went blank at the same time all hvac stoped even rear defrost
Old Jan 27, 2019 | 10:08 AM
Originally Posted by ckev70
It sounds like there is no air coming out of the vents in AC or Heater mode. If this is the case, the heater resistor has failed. Honda calls it a Transistor, Power
https://www.hondapartscheap.com/oem-...QtYXV0b21hdGlj
Image of part
https://www.google.com/imgres?imgurl...act=mrc&uact=8
It's located behind the glove compartment on the left. Held by 2 screws and inter screw is difficult to reach due to the position.
There is a way to repair the failed unit but that is another story.
There is no hvac being displayed on the radio.
Old Jan 27, 2019 | 10:54 AM
Originally Posted by chriszito81
fuse #30 7.5 is ok and power heated seats and mirrors work
Outside temp, rear defrost and more are all controlled by the HVAC "head unit". Since the fuse is good, you are pretty much now down to testing at the HVAC control unit. There are two connectors at the unit, a 16 pin and a 22 pin.
On the 16 pin connector (again remember all pins or slots may or may not have a wire but they are counted), pin four is a blk/yel wire that should be hot (battery voltage) when the key is on - you need to verify this.
Then on that same 16 pin connector, pin six should have continuity to ground - you need to verify this.
Please verify the two above and let us know what you find on those two pins/wires.
Old Jan 27, 2019 | 05:35 PM
power only 10v
Old Jan 28, 2019 | 07:49 PM
what are you using as your power and ground when you measured 10V?
Old Jan 29, 2019 | 05:50 PM
so my battery was dieing when i tested so i charged my bat and i have 12v on my #4 pin and ground on #7 pin or body ground same also 12v at the transistor and 12v at the blower motor.......
Old Jan 30, 2019 | 07:51 PM
  #17
Shana Storm
Sep 15, 2018 10:05 AM
Leifin615
Oct 25, 2017 06:45 AM
j894
Feb 8, 2014 06:41 PM
fxgo
May 30, 2009 05:03 AM
dorknob
Dec 27, 2006 08:24 PM
