07 Accord EX 2.4 tail lights and license plate lights not working
Old Aug 25, 2023 | 05:11 PM
Rory1983's Avatar
Default 07 Accord EX 2.4 tail lights and license plate lights not working
Wife was driving home from work last night and got pulled over for tail lights not working and also license plate lights it has the led tail lights all fuses appear ok
Old Aug 25, 2023 | 07:09 PM
Do any lights on the back of the car work?
Old Aug 25, 2023 | 08:07 PM
Rory1983's Avatar
Yes brake lights and turn signals are working
Old Aug 25, 2023 | 10:56 PM
Has any recent work been done on the car or has it been in an accident?
All lights that are out share a common power source. It starts with fuse #4 15A in the engine bay fuse box. Use a volt meter or test light to see if the fuse has power on both sides with the fuse plugged in. Look on youtube for videos on how to quickly check car fuses.
If that fuse is blown, replace it. I suspect that the fuse will quickly blow if you have some kind of short in your wiring system.
You can also try unplugging a non-working bulb and check for power and ground on the two wires to see what you are missing to be 100% sure if you have a power side or ground side problem.
If the fuse isn't blown and has power, then a relay that part of the relay control module is the next step for testing. Unfortunately, I believe that relay is integrated into the fuse fuse box and might be a pain to test.
dmaddy44
Nov 9, 2013 09:31 AM
spyun88
May 9, 2011 11:34 AM
wh0uis
Apr 25, 2011 10:13 AM
dre707
May 14, 2010 09:03 PM
05cord
Feb 4, 2006 09:41 PM
