07 accord lx 5sp manual vss trouble
Old Oct 28, 2011 | 11:55 AM
az4438's Avatar
Question 07 accord lx 5sp manual vss trouble
I've aqiured a 2007 Accord LX with a 5sp manual from my daughter, the clutch was replaced reciently, do to idiot drivers (not her). The trans VSS was removed and then replaced in tranny. when I picked the car up the sensors anchor bolt was not tight. I discovered that the sensor head had been knocked off. replaced it with a new one from honda. Drove the car about 50 ft when it died. Pulled the sensor out and the head on the replaced sensor had been tore off also. Could a piece of the original sensor tip be stuck inside the tranny where the sensor is located? Any ideas before I tear the tranny out again?
Old Oct 28, 2011 | 12:24 PM
After you remove the speed sensor (aka pick-up assembly), examine to see if it is intact. (The attached picture from CarQuest shows how it should look like intact.) Make sure when you install a new one, to also install the washer, #12 in parts diagram, it is works as a spacer too.
Attached Thumbnails 07 accord lx 5sp manual vss trouble-speed-sensor.jpg   07 accord lx 5sp manual vss trouble-pick-up-assembly.jpg
Old Oct 28, 2011 | 07:42 PM
az4438's Avatar
Default Problem sloved I hope
Thanks for the input. The person who installed the clutch told me to bring it by and he would put a Shim under the new pick up assembly. I thought that comment was a little odd, now i know he forgot to put the washer back on the original one. Thanks again
Old Oct 28, 2011 | 08:30 PM
No problem. Yep, that's what I was suspecting had happened which contributed to the problem.
vetski179
Aug 19, 2015 08:32 PM
davntaz
Apr 11, 2015 09:10 PM
Flatline1121
Jun 5, 2008 08:54 AM
98accordlx
Feb 11, 2008 11:32 PM
comptoncarl
Feb 8, 2007 03:04 PM
