'07 Accord V6 - Noise in the front
Old Jul 8, 2012 | 07:42 PM
tcmw's Avatar
Question '07 Accord V6 - Noise in the front
I'll do my best to explain what I am hearing but it might be a little difficult.
I have a 2007 Accord V6 EXL with about 55k miles on it and recently I have been hearing this (almost) faint whistling? noise in the front of my car... I hear this noise when I am traveling at low speeds (~5-20 MPH) whenever I put a little pressure on the gas pedal. It may be happening at higher speeds but with road noise I can't tell. The noise goes away whenever I take my foot off the gas.
I can particularly hear the noise when driving past parked cars or when I am driving up a steep incline, like my drive way.
When the car is in park I don't hear anything suspicious, but (when still in park) that noise will reappear when I press the gas... same when in N.
I took the car into my local Honda dealer a few weeks ago and they couldn't reproduce the noise (they only had it for a limited time) but they said if I heard it again then I should bring it back and they will dig deeper.
Just wondering what everyone else thought... not sure it would be a wheel bearing since I can still hear that noise when in park and when I press on the gas.
I'm gonna make another appointment this week and see what they find.
Old Jul 8, 2012 | 07:48 PM
If you hear the noise when the car isn't moving, then it is unlikely a suspension/bearing problem.
It could be from the serpentine belt, or one of the components it drives.
Old Jul 8, 2012 | 07:59 PM
It may be due to the idler pulley. See Honda technical service bulletin, it has a sound clip too.
TSB 08-045
Also see this youtube video:
"http://www.youtube.com/watch?v=cOv1zvk9IyM"
Copy and paste video link without quotation marks (" " ) to view.
Old Jul 15, 2012 | 09:35 AM
tcmw's Avatar
I'm not much of an engine person but could it be the timing belt? In my manual it says you should replace that at 60k miles and I'm at 55k right now.
Old Jul 15, 2012 | 06:44 PM
EXV6NIGHTHAWK's Avatar
The regular interval, for the timing belt is 105k miles. I believe 60k is for "EXTREME" climates (below -20 degrees, or above 120 degrees). Is your car "regularly" driven in these temperatures?
Old Jul 16, 2012 | 04:16 PM
tcmw's Avatar
No not at all.
Old Jul 16, 2012 | 04:41 PM
No not at all.
That doesn't mean that something related to the timing belt isn't making the noise. Just saying, unless you live in an extreme climate, the timing belt isn't due to be changed until 105k miles. You could eliminate anything being driven by the drive/accessory belt, by removing it, and see if the noise goes away. Just don't run the engine without the drive belt for very long, because the alternator will not charge the battery, or try to drive it without the power steering.
thepacifist
Jul 12, 2010 09:45 PM
4doordriven
Jul 13, 2009 03:41 AM
Rickasas
Mar 27, 2009 12:24 AM
dsettlemoir
May 4, 2008 10:57 PM
OldFox
Jun 4, 2006 05:26 AM
