2001 Accord front wheel noise
Old Mar 26, 2009 | 02:18 PM
Rickasas
Default 2001 Accord front wheel noise
We cant figure out what is making the thumping noise in the drivers side front wheel area. A mechanic checked the strut and said it seemed fine,but the noise sound just like a loose shock/strut. Any help would be appreciated.
Old Mar 26, 2009 | 04:58 PM
Check for any loose ball joints?
Check for loose suspension pivot bushings?
Loose anti-roll bar bushings?
IF you rule that stuff out, check out whether a TIRE is going bad. The belts can do funny things, shift around & make noises & go out of balance. Not too common, but it does happen. Check that by swapping tires around.
Old Mar 27, 2009 | 12:24 AM
mreid10
as dumb as this sounds... the same thing happened to me during this past winter. I just put my snow tires on and my front left went flat, so I put on my spare. I drove around for 2 weeks and it started making a thudding/thumping noise whenever i turned a little bit, even going straight. My buddy and I decided to check if the rotar was messed up, but when I tried taking off the lugnuts, they were VERY loose. So i decided to tighten up the lugnuts rather than put the fixed snow tire back on, and wah-lah! no more thudding... but now my brake rotar has a nice smoother edge since the tire leaned on it while i drove it for two weeks.. good luck!
indy49
Dec 14, 2011 10:59 PM
bbugara
Dec 10, 2011 06:32 PM
DAMc
Nov 12, 2009 05:54 PM
4doordriven
Jul 13, 2009 03:41 AM
OldFox
Jun 4, 2006 05:26 AM
