08 honda accord 4 cyling alt bolt froze
Old Sep 5, 2021 | 07:45 AM
Blakeshonda's Avatar
Default 08 honda accord 4 cyling alt bolt froze
My 08 4 cylinder accord alt went out trying to remove old alt. 1 bottom bold will not break free. using pb blaster and wiggling alt back and forth with hopes the nut will free up. Any other suggestions
Old Sep 6, 2021 | 11:02 PM
I can't see the second bolt in the pics. Penetrating oil and some minor force can help. Hopefully it resolves the problem.
More leverage can help, but you risk snapping off the bolt. Heat is helpful, but you have to be careful around wiring harnesses and aluminum parts. I know my map gas/oxygen torch can heat the aluminum to the melting point.
I think the 08 alternator setup has a tensioner, so the alternator doesn't pivot to hold belt tension.
Hopefully you already resolved the issue.
Old Sep 7, 2021 | 07:14 AM
Yes we got it off by using a pry bar and gently working it free. A gentleman who is a retired mechanic knew of THS problem and was well aware of the options. I'm very grateful for his help.
Old Sep 7, 2021 | 07:53 AM
I do have a helpful suggestion. We had more room to work under the hood with better light by raising the hood up on a 45-degree angle propped with a board. Just make sure the wind won't grab it. Made the job much easier.
biglou1856
Feb 6, 2009 12:50 PM
tougefreakEvo
Aug 12, 2008 03:50 PM
markharrison
Jul 8, 2008 03:47 PM
Tasman
Jun 16, 2008 01:20 AM
