09 Accord LX Fuel Filler Door Hinge
Old Dec 4, 2009 | 04:07 PM
likir
Default 09 Accord LX Fuel Filler Door Hinge
I am having trouble getting the fuel filler door to open consistantly. The dealer adjusted the cable and it seemed to work for awhile but the problem still exists. Sometimes it opens the first time I push the lever inside, other times it takes 20+ pushes to finally get it open.
I compared my fuel door to a co-workers 2009 Accord fuel door and I noticed that his door had more "tension" or "spring" in the hinge. So it seems the problem is not in the cable but in the door hinge. Can it be adjusted? Is there an actual spring in the hinge that could be replaced? Or do I need to get a whole new fuel door?
Thanks for your help. This forum is great!
2009 Accord LX
Old Dec 4, 2009 | 05:16 PM
Since you have an 09, take it to the dealership for the work. It should be covered under the factory warranty.
Old Dec 4, 2009 | 06:45 PM
kris_loehr's Avatar
I don’t what the 09 filler looks like but the cable just release the filler door and it has to have something to spring it open.
Old Dec 7, 2009 | 07:51 AM
I think it's just a little spring-tab right at the door hinge. You should be able to bend it a bit to give more tension, but it should be covered by warranty.
Old May 22, 2014 | 12:25 PM
mikecu's Avatar
I finally got fed up, and fixed mine.
I pulled lever assembly out and saw that the cable has a position adjustment.
It was just a matter of pulling the cable out and putting it back on a different slot. You have 3 positions to choose from. I moved it from the middle one to the 3rd counting from the front. This gives you about 3 more millimeters of cable throw.
Once you know what to look for, this job takes about 5 minutes.
smiyares
May 24, 2017 07:39 PM
Ron1979
May 12, 2015 09:09 AM
bostongrun
Jun 23, 2012 12:13 AM
whb52ford
Mar 31, 2011 07:06 PM
techman2015
Feb 15, 2011 09:11 AM
