1983 Gen 2 1600 auto won't shift
Old Jan 21, 2012 | 08:38 PM
outrigger's Avatar
Default 1983 Gen 2 1600 auto won't shift
Hi All,
I have a 1983 Accord 1600 with a 3 speed auto which I inherited from my aunt. Its only done about 85000 miles and has been well looked after and regularly serviced. I don't know how reliable to servicer is so I can't vouch for how long this problem has existed, but my "auto" box is really quite manual. It will drive in all 3 gears, but OD only engages 3rd, (*) second, and L first. So to drive around normally I have to shift myself. Not too bad really, but it could mask a problem and I'd rather have it sorted. Any thoughts? Thanks!!
Old Feb 17, 2012 | 07:40 PM
outrigger's Avatar
bump!
Old Feb 18, 2012 | 08:01 AM
Best I've got on this gen.....if there is a throttle control cable, then I would look into checking it is adjusted and moving correctly.....
Old Feb 18, 2012 | 01:40 PM
joec44's Avatar
First thing I would do is drain the teanny. look for junk in fluid reload with honda stuff and go for a good hard road test valve body may have a valve hanging up. Oh yea one moor trick I remember is to put it up on jack stands and run hard in reverce may also have govener hanging up good luck
Old Feb 24, 2012 | 08:31 PM
outrigger's Avatar
Thanks for the starting points guys, I'll post back soon. Got some time off work coming up so I can get it in the garage and pull it apart. Got an alternator to replace now while I'm at it
Old Feb 25, 2012 | 08:01 AM
kyle102565's Avatar
hondas dont have governors.
Albank
Apr 8, 2015 11:52 PM
chrishead
Sep 25, 2012 05:29 PM
tumminello123
May 23, 2010 01:44 PM
fdunlap
Sep 18, 2008 07:10 PM
sir_nasty
Jan 12, 2008 05:17 PM
