transmission rattle at 1600 rlpm
Old Apr 8, 2015 | 02:32 PM
Albank's Avatar
Default transmission rattle at 1600 rlpm
My 2011 Accord had its automatic transmission fail at 70,000 miles and was replaced under warranty. Now at 130,000 miles I have a noise that sounds like a loose heat shield that occurs between 1500 and 1600 rpm in each gear. It happens both going up through the revs and back down. No loose components have been found and it only happens when in gear.
Any ideas?
Old Apr 8, 2015 | 11:52 PM
The heat shield around the catalytic converter is a good place to start. Look carefully around the bolts for small cracks and some rust.
outrigger
Feb 25, 2012 08:01 AM
filmstar17
Jun 13, 2011 07:01 AM
sir_nasty
Jan 12, 2008 05:17 PM
Dinjoe
Apr 18, 2006 08:44 PM
J dizzle
Jan 15, 2006 11:08 AM
