1983 cooling fan dont run
Old Sep 17, 2008 | 07:16 PM
fdunlap
Default 1983 cooling fan dont run
I am not familiar with accord, but I have no power going to the cooling fan....what is the most likely problem
Old Sep 18, 2008 | 10:28 AM
falkore24's Avatar
Default RE: 1983 cooling fan dont run
Water temp sensor ...... or a few other things ..... look in the DIY section
Old Sep 18, 2008 | 07:10 PM
hondadude's Avatar
83model has a temp sensor switch located in the bottom of the radiator, passenger side.
You can unplug the connector and jumper the wires; then turn on the key and the fan should run.
If the fan does not run check under hood fuse panel relay/fuses
chrishead
Sep 25, 2012 05:29 PM
outrigger
Feb 25, 2012 08:01 AM
CDJDM07
Aug 24, 2011 09:51 AM
tumminello123
May 23, 2010 01:44 PM
Equalizer
Feb 20, 2007 08:57 PM
