1983 cooling fan dont run
83model has a temp sensor switch located in the bottom of the radiator, passenger side.
You can unplug the connector and jumper the wires; then turn on the key and the fan should run.
If the fan does not run check under hood fuse panel relay/fuses
CDJDM07
Aug 24, 2011 09:51 AM
tumminello123
May 23, 2010 01:44 PM
