1985 Accord A/C Fresh Install
AC thermostat is necessary. It may be mounted on the evaporator assy you must purchase.
You may need a heater control panel to have the AC on/off switch. I doubt your no AC heater control has the switch. Manual wiring likely necessary.
You have all the major components listed. What you are missing are the other items that control the a/c. I have no idea how the a/c is wired and controlled, so you may need those parts. The various brackets/clips to secure all the a/c components.
Just looked at hondapartsnow.com, there is an a/c solenoid and vacuum tubing. My guess is this is to increase the idle while the a/c is turned on, but I am not sure. Suggest going through that parts site to see what components are necessary. Since there is a vacuum control on the a/c, check that your intake manifold has the proper vacuum connection. It could be possible that you would need a different intake manifold. You will have to do your research on this.
I also suggest finding/purchasing a shop manual for your car.
Also finding a parts car at a u-pull-it yard will help a lot too.
blackspec44
Jan 14, 2013 11:48 PM
godzilla_753
Jul 29, 2010 08:03 PM
