1985 Accord A/C Fresh Install
Old Jun 5, 2016 | 03:29 PM
AC thermostat is necessary. It may be mounted on the evaporator assy you must purchase.
You may need a heater control panel to have the AC on/off switch. I doubt your no AC heater control has the switch. Manual wiring likely necessary.
Old Jun 5, 2016 | 03:38 PM
You have all the major components listed. What you are missing are the other items that control the a/c. I have no idea how the a/c is wired and controlled, so you may need those parts. The various brackets/clips to secure all the a/c components.
Just looked at hondapartsnow.com, there is an a/c solenoid and vacuum tubing. My guess is this is to increase the idle while the a/c is turned on, but I am not sure. Suggest going through that parts site to see what components are necessary. Since there is a vacuum control on the a/c, check that your intake manifold has the proper vacuum connection. It could be possible that you would need a different intake manifold. You will have to do your research on this.
I also suggest finding/purchasing a shop manual for your car.
Also finding a parts car at a u-pull-it yard will help a lot too.
99Accordi4
Apr 11, 2015 12:29 AM
CD5.
May 3, 2014 01:20 PM
blackspec44
Jan 14, 2013 11:48 PM
godzilla_753
Jul 29, 2010 08:03 PM
g6ex6
May 5, 2005 09:03 PM
