1989 accord CV boot question
Old Jun 18, 2009 | 10:44 PM
ohanahorse's Avatar
Default 1989 accord CV boot question
Hi,
I'm trying to replace a cv boot on an 89 accord LX (passenger side)..is the axle nut thread a "righty tighty-lefty loosie" or is it reverse thread??? thus far, I am unable to break it loose...even with some "extension"
Help would be appreciated...thanks
Old Jun 19, 2009 | 01:54 AM
finch13's Avatar
It's a regular thread bolt.
Did you straighten out the part of the nut that is punched into the axle? I bought a 36mm wrench for $10 and just jump on it to loosen mine. Tightening torque is 181-ft. lbs.
Old Jun 19, 2009 | 07:06 AM
I use a 4-foot pipe over my breaker bar...
Old Jun 19, 2009 | 11:56 AM
This nut can be brutally tight. I've found a good air impact is usually successful. A good 1/2" x 18"L breaker bar w/ 2-3 feet of cheater pipe as suggested by JimBlake is also a sure thing. You may need a jack stand to support the extension/breaker bar head to allow you to pull on the business end of the breaker bar w/ extension.
Old Jun 19, 2009 | 08:38 PM
hondadude's Avatar
doo dee doo dee doo....Just thought I might stop by and offer up this little trick.
Use the weight of the car to generate the force.
Put the socket on the nut [tire back on without hub cap] then put the end of the breaker bar handle close to the ground.
Rock the car.
All that is needed is to be smarter than a nut. LOL ;-]
jerrym
Dec 27, 2014 10:43 PM
DanielC.Young
Aug 6, 2012 04:18 PM
cory_fisher91
Apr 2, 2010 05:11 PM
bamaccord
May 22, 2009 03:41 PM
honda285
Dec 16, 2008 07:28 PM
