1989 Accord DX Carb 2.0 Cooling fan not working
Old Jul 24, 2012 | 07:34 PM
Justin Hastings's Avatar
Default 1989 Accord DX Carb 2.0 Cooling fan not working
My 1989 Honda Accord DX 2.0 Carb main cooling fan is not working when vehicle is on and wants to overheat. Main fan is supposed to come on with the key off and cool down the motor. Not coming on.
I looked at the wiring diagram, changed the cooling fan relay. Changed out the cooling fan switch in the radiator.
Checked the wiring at the relay making sure I had 2 powers to the relay. Jumped the relay to both terminals; only 1 terminal turned on both fans. The other terminal did not.
The car does have a fan timer underneath the passenger seat. I've seen on another website someone suggesting to change that and haven't checked that yet.
Besides checking the fan timer is there any other suggestions to getting the fan working properly?
Thanks.
Old Jul 24, 2012 | 08:55 PM
Do a simple test, put 12v to the motor and see if it runs.
Does the ac still work on this car?
.....ps, when the car is on and the temp gets to a "set point" BOTH fans should run.
onemandeep
Jan 30, 2014 04:49 PM
mirror
Apr 22, 2013 05:38 AM
rolling
Jul 26, 2012 09:48 AM
CDJDM07
Aug 24, 2011 09:51 AM
Equalizer
Feb 20, 2007 08:57 PM
