cooling fan not working without ac
Old Apr 21, 2013 | 11:04 AM
mirror's Avatar
Default cooling fan not working without ac
My cooling fan is not coming on without turning the ac on. I have a 98 4 cyl, stick shift accord and it is overheating now. It even seems to be overheating when the ac is on due to fan shutting off at times. Where do I need to check first and last if you could. I can continue to drive and it won't heat up but at stop it goes up fast. The weird thing is as soon as I take off it might cool down immediately or it might stay up a while.
Old Apr 21, 2013 | 11:12 AM
I'm leaning towards the rad fan switch.
When the ac is on - do BOTH fans on the rad run?
Old Apr 21, 2013 | 11:30 AM
mirror's Avatar
Yes but then I think I am low on freon so the compressor is kicking off and they both turn off. I have checked into it and it looks like it might be something simple just posted to soon. Looks like a leaky radiator and the water was low. How often should the fan run when the radiator is hot without the ac. I just want to know if I have 2 problems.
Old Apr 21, 2013 | 11:38 AM
No I think you have one problem....or one I would start with and see if that resolves the second.
If there is air in the system - low coolant - then the fan switch will not read the temp correctly and not turn the fans on.
Resolve the coolant issue first. Find the leak and repair it. Be sure to properly bleed the air from the system - follow the procedure as Honda's do not like air in the cooling system.....for reasons like the fans not coming on
Old Apr 22, 2013 | 05:38 AM
mirror's Avatar
I appreciate the help and yes I will correct the leak before doing anything else.
onemandeep
Jan 30, 2014 04:49 PM
rolling
Jul 26, 2012 09:48 AM
Justin Hastings
Jul 24, 2012 08:55 PM
CDJDM07
Aug 24, 2011 09:51 AM
Equalizer
Feb 20, 2007 08:57 PM
