1989 accord Engine started making a popping sound
Old Jan 19, 2007 | 02:58 AM
igot2gonow's Avatar
Default 1989 accord Engine started making a popping sound
Hi I have 89 accord auto trans 132k runs fine. I was driving it today and it started making a popping sound from the engine. The noise increases with rpg and is slow at idle, but goes away when decelerating. The engine runs fine and no loss of power or missing. It runs completely normal like it always has. . Sounds like an old VW with an exhaust leak. I drove the car home at a slow speed and parked it.
Any ideas?
Larry
Old Jan 19, 2007 | 11:29 AM
deserthonda's Avatar
Default RE: 1989 accord Engine started making a popping sound
like you say ,, you might want to inspaect the exhaust system for leaks .. also chk the timing
Old Jan 19, 2007 | 01:47 PM
If it's slow enough to hear individual pops, maybe look for leaks where the exhaust manifold bolts to the head. Further back, an exhaust leak wouldmake moreof a continuous rumble sound.
Old Jan 19, 2007 | 01:50 PM
sir_nasty's Avatar
I'd also check your heat shield on the exhaust to make sure that it's tight/in place well... check your timing like desert said and make sure your plug wires are all on securely
Old Jan 19, 2007 | 02:24 PM
igot2gonow's Avatar
Thanks one and all. Yup, two of the exhaust manifold bolts fell off or broke. Now for the fun job of fixing it.
Again, thanks
Old Jan 19, 2007 | 04:19 PM
sir_nasty's Avatar
at least they are out (hopefully) since removing them is the hard part *L*
Old Jan 20, 2007 | 02:03 AM
igot2gonow's Avatar
Ya, exhaust nuts are the worst. In looking in my repair manual I found out they are studs, not bolts. So, it's R & R the manifold and replace the studs. I'm going to take to my local repair shop and get it fixed.
Any idea on how much it will cost?
Old Jan 20, 2007 | 05:09 AM
Yo DO NOT have to install studs and nuts,, just install bolts and washers..save yourself a lot of money .....I have done it before on a few occasions same the customers some money , no problems
make sure that the threads are not stripped
iggys-amsoil
Apr 18, 2014 06:18 PM
MisterBen
Jun 28, 2010 05:09 PM
crack3d
Jun 24, 2010 05:02 PM
ohsmustangs09
Jun 22, 2007 02:31 PM
CyberGrnBug01
Jun 1, 2007 01:58 PM
