1989 auto to manual?
Old Feb 10, 2013 | 09:41 PM
wildeboy11's Avatar
Default 1989 auto to manual?
I have a 1989 Honda Accord (automatic) the reverse doesnt work. would it be cheap to swap it to manual or keep automatic?
Old Feb 12, 2013 | 07:52 AM
I moved your post out to it's own thread, to avoid confusion with the other one.
Old Feb 12, 2013 | 08:16 AM
shipo's Avatar
The cheapest solution would be to either have your current transmission fixed or to replace it with another automatic. The best solution (from my perspective) would be to swap the tranny for a manual, however, that "swap" entails a considerable amount of money, work, and patience to pull off.
Old Feb 12, 2013 | 10:27 AM
wildeboy11's Avatar
ok thanks but i heard if i put another automatic one in it will most likely break.
Old Feb 12, 2013 | 10:35 AM
shipo's Avatar
Yes, sooner or later, however, a decent rebuild should last an easy 100,000 miles; how much longer to you plan on keeping your car?
Old Feb 12, 2013 | 11:16 AM
Rebuild = more $
Junkyard used transmission = probability of another failure
Depends on what you mean by "another automatic".
I'm a big fan of having 3 pedals on the floor, so my choice would be manual conversion. But it's not MY car or MY money.
Old Feb 12, 2013 | 02:17 PM
Hamster108's Avatar
honestly, I would go for a rebuild. I can post all the schematics you need for the job, and replacement clutches are dirt cheap. Go to harbor freight and autozone and buy the tools you need and you can rebuild it in your garage.
Old Feb 12, 2013 | 03:52 PM
shipo's Avatar
Originally Posted by JimBlake
Rebuild = more $
I too am a fan of the three-pedal setup, however, I believe it is better/cheaper to swap cars than it is to try and retrofit a manual into a car originally built as an automatic.
Old Feb 12, 2013 | 09:00 PM
What is the fluid level (proper procedure for checking) and condition?
DX,LX or LXi?
cliff
Apr 15, 2013 02:27 PM
lindsey453
Dec 29, 2012 10:39 AM
darrenf6
Jul 29, 2012 02:56 PM
Max Utility
May 19, 2011 12:32 AM
saanich
Sep 29, 2009 02:41 AM
