1990 accord ex 43 code
Old Jan 20, 2006 | 11:40 AM
mongol
Default 1990 accord ex 43 code
hello everyone, have gone thru the manual to check for this problem .the solution in the manual suggests to replace the ecu,did that and still have the problem .also have put in a new o2 sensor. can anyone help thanx.
Old Jan 20, 2006 | 02:08 PM
lightshow's Avatar
Default RE: 1990 accord ex 43 code
what i want you to do is drop your cat out the bottom. there are three nuts that hold it on both sides. take it for a quick rip its gonna be loud as **** but if it runs better thats your problem. it could easily be something in the fuel system too. filter, injector, regulator. LET us know how it goes, i feel useful if i actually help someone.
lightshow
Old Jan 21, 2006 | 01:26 AM
mongol
thanks for response one thing i forgot to mention that i noticed is the engine wont turn back on till i get on the freeway for about ten minutes or get over 70.
Old Jan 21, 2006 | 08:38 AM
lightshow's Avatar
well drop out your cat it might be plugged. if it is then it needs to be replaced.
lightshow
Old Jan 27, 2006 | 06:42 PM
mongol
dropped the cat it was okay same problem engine lite turns on
Old Jan 27, 2006 | 06:58 PM
lightshow's Avatar
the ecu will store the code until 5 no code starts are performed, its how well the engine runs. the 43 code is the fuel system. i would start by replacing the fuel filter. usually the pump either works or doesnt. but i would check the fuel pressure with a guage at the banjo fitting...pressure should be 30 psi approximately. if you have bad fuel pressure than your pump is bad or the regulator is bad. if pressure is fine and you have changed the filter and the code is still on, then it may be an injector.
lightshow
Old Feb 1, 2006 | 08:59 PM
mongol
checked the pressure it was ok ,replaced the filter checked injectors they were clicking and resistance was fine.now the car is slow to take off lite still comes on once i hit 2800 rpms or +70 mph
fcmoozin
Jul 25, 2012 07:15 PM
Rtherres
Jan 30, 2011 04:58 PM
churritos567
Sep 30, 2010 01:19 PM
tiredredcoupe
Dec 26, 2009 03:09 PM
kashatria
Jul 20, 2007 05:58 AM
