1990 accord ex highbeams wont stay on
Old Sep 5, 2014 | 07:54 PM
panzo's Avatar
Default 1990 accord ex highbeams wont stay on
Hello folks, just bought myself a 90 accord due to its known bulletproofness.
I'm having one issue I would like to resolve as its driving me nuts:
The highbeams don't stay on! I pull the stalk on the dimmer switch/headlight switch and the high beams turn on, but as as I release they turn off.
I can flash the high beams by pulling and releasing the stalk/switch but they just won't stay on. I already changed the dimmer/headlight switch at the steering wheel, but the problem still persists.
Please help thank you!
Old Sep 5, 2014 | 08:01 PM
That sounds like the switch itself is not working correctly..call Honda and ask if that could be your delima..one of my customers had that problem a couple of years ago and he replaced it and wolaa! problem solved..
Old Sep 5, 2014 | 08:20 PM
panzo's Avatar
That sounds like the switch itself is not working correctly..call Honda and ask if that could idbe your delima..one of my customers had that problem a couple of years ago and he replaced it and wolaa! problem solved..
Thanks for your reply which switch are you referring to? I changed the dimmer switch (stalk/headlight switch) three times, and they all do the same thing. Is there another switch?
Old Sep 6, 2014 | 08:44 AM
It sounds like the "switch" is not locking into high beams.
Check to be sure the plastic cover(s) around the column/switch stalk are not preventing the lever from moving far enough to lock the switch into high beams.
Old Sep 6, 2014 | 10:42 AM
panzo's Avatar
hello thanks for the reply, i have removed the covers for the steering column, and all three switches i have tried fully engage when pulling back , the high beams do work as they do the whole "passing" flash, when i pull ti all the way all the switches do the click, the higbeams come on if i hold it pulled, but as soon as i let go it falls back into the low beams.
Old Sep 6, 2014 | 01:45 PM
Normally this sounds like the combination switch. Since you already tried 3 different switches, the issue may be due to the dimmer relay (located in the under-hood fuse/relay box). The dimmer relay provides the ground source to the high beams.
Old Sep 6, 2014 | 07:16 PM
panzo's Avatar
Default DRL module/Relay help needed
Hello I have figured out that the drl module is not functioning properly, I need to change it, the model is rz-0089 from Mitsuba, but I can't seem to find it anywhere.....
All I keep finding only is rz-0126 mitsuba drl module will it work in my car?
1990 accord ex Canadian....
Thank you!
Old Sep 6, 2014 | 07:40 PM
Toronto Honda can possibly get it, even though it is discontinued. They check through their distribution network.
Toronto Honda Parts - RELAY ASSY., RUNNING LIGHT (RZ-0089) (MITSUBA)
You can also just resolder the solder joint on your existing unit's circuit board.
elemental_funk
May 14, 2009 09:05 AM
thedaveman89
Nov 26, 2008 03:37 PM
stoddaj1
Nov 2, 2008 01:48 PM
RondaTheHonda
May 3, 2008 11:14 AM
kangas
Mar 17, 2008 10:04 AM
