1990 accord idle troubles
Old Aug 15, 2024 | 12:28 AM
maxhlovell3's Avatar
Default 1990 accord idle troubles
Hello, I’ve been dealing with rev surge idle problems all day and finally I think I got it to calm down but now it’s idling lower than what I believe normal is. I got the car yesterday so I don’t know what it’s normal behaviors are but it’s holding about 400 right now in park with the ac off. I’m used to 600-900 on every other car I’ve had so if anyone could let me know if I’m idling too low or not that would be great. I’ll attach a picture of my tach below and note that it held that exact rpm for 5 mins until I turned it off which is great cause it’s been surging all day.
Old Aug 15, 2024 | 10:56 AM
Your idle in the picture is 700 and is normal.
The first line from zero on your gauge is 500 rpm as it is the same width as the 1500, 2500, etc. lines. Increments between each line are all 100 rpm. Not sure why Honda setup the 0-500 gap on the gauge, but I've seen others make similar mistakes when first reading the rpm.
Old Aug 15, 2024 | 11:01 AM
The first line from zero on your gauge is 500 rpm as it is the same width as the 1500, 2500, etc. lines. Increments between each line is 100 rpm. Not sure why Honda setup the 0-500 gap on the gauge, but I've seen other make similar mistakes on reading the rpm.
Well I feel like an idiot, thank you so much I couldn’t find that info out anywhere in the manual or online.
hmr
Jun 27, 2019 08:38 AM
oldskoolaccord90
Apr 11, 2012 12:14 AM
SkyhawkCaptain
Jun 12, 2011 10:26 PM
dantegl36
Aug 28, 2007 09:33 AM
goonie
Sep 13, 2006 11:27 PM
